How do you control the gripper once attached and URCap is downloaded?
Catherine_Bernier
Hi Lawrence,lawrence said:Hi can i have more then 1 IO coupling attach to 1 UR robot?
No because there is only 2 inputs and 2 outputs that the I/O Coupling is using completely.
What would be the use of having 2 coupling? Dual gripper setup?
Thanks!
Catherine_Bernier
Hi Wiley,wileydavis said:Will this work with a CB robot and the previous generation 2F gripper?
It is made for UR CB robots. The robot's PolyScope version must be 3.10 and later in order to install the URCap.
The gripper firmware needs to be GC3-1.6.8 or latest.
Thanks!
Catherine_Bernier
@lawrence, It is not possible at the moment. You would need the couplings with cable.
Thanks for the info.
DBookless
I'm working with a CB2 robot (so only PolyScope 1.8), so the URCap wouldn't be an option for me. However I'm guessing the limitation to four presets means it's just controlled by setting the two digital outputs on the tool I/O to binary 0, 1, 2 or 3, which could be reproduced fairly easily without any extra URCap or driver.Catherine_Bernier said:It is made for UR CB robots. The robot's PolyScope version must be 3.10 and later in order to install the URCap.
Is this right? Would it be possible to do something like this and use the coupling without the URCap?
Bobbypointe
Hello Pros,
As you know, connectivity problems come in as the top cause of unexpected downtime. Cable management is a serious problem when using a UR CB Series cobot, and Robotiq now offers an alternative.
The new I/O coupling allows you use Robotiq grippers (2F, Hand-E, EPick and AirPick) without running a cable along the cobot arm. As such, I/O couplings are now sold bundled with grippers in Wrist Connect Kits for CB Series cobots. Those kits can be purchased directly through your local distributor.
The I/O coupling for UR CB Series is compatible with 5 Robotiq grippers,
and lets you do away with cable clutter.
For more details on those new Robotiq kits, get in touch with your local distributor. If you have any questions, please let us know on this forum!
