We are having that issue with E-Series robots, we have never had it with any of the CB3 robots running polyscope 3.9 or older, haven't upgraded any production robots to 3.10 yet. We will be installing 5.4 shortly on the robots that have the issue to see if that helps
Pmkgur10 said:I am also faced same issue today on CB3 V3.8 UR10 robot. Teach pendant hang. Operation stopped.
Forcefully we restart the Robot.
After restart log files erased.
Profinet names got erased. I have to set every power recycle.
Payload settings changed.
Is there any file protection available.
I got confused.A colleague has already had a similar problem. The treach screen froze when he was been teachning the robot. He restarted the system and of course did not save the programs. But I'm worried about the configuration file because after any modification, this file is normaly automatically saved.Are you sure to didn'd have loaded a different backup ?
TE_TAY said:Hello!I have a problem, teach pendan CB3UR10, can not press to order. Must be connected to the MOUSE computer to operate instead What do I need to fix next?Thank you.
Hello, I had a similar problem in past. To fix the problem I asked to our disttributor to change the teach pendant cable
