So cool! Customers will love this. B)
Alexandre_Pare
@preciadoe
This is what I have been talking to you about in my last email! Would this be useful for what you want to do?
Nicolas_Lauzier
@matthewd92
It is possible to record the path with the sensor and check the "Relative" option. This option does two things: 1) it plays the path relative to the robot position when it enters the instruction and 2) it plays the path using Cartesian (x-y-z, not joint positions) using the TCP information. In your case, you only want 2).
Therefore, you can add a standard move to a fixed waypoint before the "Path" instruction and select the "Relative" option. As such, you will be able to change the TCP after you remove the sensor and the path will be compensated.
As @Alexandre_Pare said, you can only record and change the path options when a sensor is plugged in. Without sensor, all the command screen of the "path" instruction will be greyed and not clickable but the path will still be played.
Nicolas_Lauzier
@engmgr, it is not planned to release this software on Motoman Robot.engmgr said:Will there be a version that will work with a Motoman Robot?
However, we do have a similar product on Motoman, Kinetiq Teaching . It does not allow to record continous paths. However, it allows to guide the robot and save various waypoints (joint, linear, circular) in order to produce an INFORM job. It was designed for welding applications (it has some icons for welding options, for instance) but I know that some people use it in other applications, i.e. to teach a sequence of points, save an INFORM job and then add some other instructions (gripper, etc.).
Alexandre_Pare
Hey all,
I thought I would post this here since this video shows the king of application where this new trajectory recording feature can really make programming easier. I was looking at one of our client's website, Filter Design Company LTD in the UK and came across a really nice video. It is a glue dispensing application using the 2F85 Robotiq gripper that is holding the component during the glue dispensing process.
https://www.youtube.com/watch?v=DfkcvX-qDRA
Olivier_Grenier
UPDATE!
You can click here to download the .urcap file.
**Please note that in order to install this file, you need UR beta software 3.3.0.111 (beta 3) on your robot as it uses functionalities that are not released yet. Robotiq cannot distribute the UR beta software so this trial is only available if you are in the UR beta distribution list. You also need a Robotiq Force Torque Sensor (FT 150 or FT 300) in order to use the beta software. It is still in beta so do not hesitate to contact us if you encounter any issue.**
Samuel_Bouchard
@mdemm @Ryan_Weaver @gradyturner86 @PaulKeeling @AlexYust @Enric @Kaleb_Rodes : Want to give a try to the beta? Let us know how it goes!
Samuel_Bouchard
@matthewd92 we'll contact you on this, thanks for the offer!
FYI
The Universal Robots Software 3.3.0.145 is now available.
Link to download: Click Here
eric
I'm very excited about this and the capabilities it brings to various applications. Thanks guys!
Alexandre_Pare
If you are looking for more info about the new UR Software and how to install the UR Caps, check out this link!
If I recall it right, servoj doesn't support as conveyor tracking is doing a shifting of the tcp in conveyor direction. Since you are using servoj there is nothing for conveyor tracking to work with and it may ignore it.Nicolas_Lauzier said:@gerenga, the actual code moving the robot is the script function "servoj". We haven't made tests with conveyor tracking but if servoj supports it, it should behave the same way with the Path Recording functionality.
However just a guess, would have to be confirmed.
Samuel_Bouchard
Hi Everyone, here is a new public video (not as good at the one of @Enric of course :smile: ) if you want to share the word with colleagues:
https://www.youtube.com/watch?v=9iCLK__7ymY
You can also find a blog post explaining the software as well as the new gripper interface on polyscope.
mdemm
markus_rothtechnik
Enric
Hi everyone,
Here is an exclusive demonstration of a new software (which we will launch soon) that allows you to program a robot's trajectory in seconds.
Do you have specific applications in mind where this software would be particularly useful? Let everyone know below :)
Here is the video demonstration only for DoF members:
Disclaimer: Licensing and Liability
As a Beta site, you receive a temporary license to use the Beta software until Robotiq inc. revokes that right or until the product officially ships, whichever comes first. You understand that the Beta software, documentation, and any updates may contain errors and are provided for limited evaluation only.
You agree that this Beta software is licensed to you on an "AS IS" basis without any warranty of any nature. ROBOTIQ INC. DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
ROBOTIQ INC. SHALL NOT BE LIABLE FOR ANY DAMAGE OR LOSS, WHETHER DIRECT, INDIRECT, SPECIAL OR CONSEQUENTIAL (INCLUDING LOST PROFITS), ARISING OUT OF OR RESULTING FROM YOUR POSSESSION OR USE OF THE SOFTWARE (INCLUDING DATA LOSS OR CORRUPTION), REGARDLESS OF WHETHER SUCH LIABILITY IS BASED IN TORT, CONTRACT OR OTHERWISE.
You may not and you may not permit others to (a) disassemble, decompile or otherwise derive source code from the Software, (b) reverse engineer the Software, (c) modify or prepare derivative works of the Software, (d) copy the Software, except as expressly permitted in this Agreement, (e) rent or lease the Software, (f) use the Software, (f) use the Software in any manner that infringes the intellectual property or other rights of another party, or (g) transfer the Software or any copy thereof to another party.
