After I program the UR robot and testing one parts, it missing the position I program and moves to the left or right . We use a vacuum gripper to pick and place parts. So, what causes the robot missing the position(waypoint)? I highly appreciated for the help.
@tom24, it would be easier if you'd share the program txt an urp files. If you could also point out which waypoint is skipped.
Almost all the waypoints the program, it moves the waypoint to the left and after re-program gain works good only one part and it moves to the right on the next parts.pallet pattern: corner1_2 Corner2_2 corner3_2 corner4_2 palletsequence Approach_2 pallet_A Set Vacuum =on Wait:.001 Exit_2Movej Wait here waypoint_5 waypoint_6 waypoint_7moveL waypoint_8movej waypoint_9 Set air_blowing=on wait:2 Set airblowing=off waypoint_10moveL waypoint_11 wait:.5 waypoint_12movej waypoint_13 waypoint_14 air_blow_1 Set air _blowing=onmoveL air_blow_2 air_blow_1 Set air blowing=off Vacuum =off Wait:0.5movej waypoint_15 waypoint_16 waypoint_17 waypoint_18 waypoint_19
@tom24, the URP file would allow us to take a look at the program. There is no obvious reason why a waypoint would be skipped.
