i want to communicate between gripper hand-e Ethernet ip and kr c4 compact kuka controller port Ethernet ip, in workvisual add eds Ethernet ip file of hand-e, i mapped inputs and outputs, the com led is stable but i dont know how to actívate the gripper.
Hello @vic,
If you mapped the registers, you'll then be able to control the gripper using the commands described in section 4.7 of the manual.
Section 4.7.6 shows an example of a gripper activation command:
thanks David_Gariepy,
i will Check that the inputs and outputs are correctly mapped and allow me to activate and deactivate
