We just had a UR3 with the same fault on wrist 3, we also saw that we were getting C70 errors which is gear box near shear limit. We had to replace the joint as it had failed.
Have you tried following the cold reboot procedure as prescribed in the service manual?
2016
Oh ok.
Thank you for the help. I will update later.
Im getting an error for wrist 2. It is C39A5 Logic and Termporal Monitoring Fault: Too fast state change.
