When ordering your new Robotiq device, you need to order the right components to install it on your robot flange without hassle. Usually, most Robotiq products need a coupling designed for the robot flange you have and sometimes an adapter plate is necessary.First you need to determine the Pitch Circle Diameter (PCD) of your robot flange.Then, you need to look for this PCD in the available couplings for each product.If your robot PCD is greater than the actual device diameter, you’ll need an adapter plateRobotiq devices commonly have a diameter around 75 mm, so any robot PCD greater than 60 mm (approx.) would need the consideration of an adapter plate.Here are the different couplings and adapter plate available for each product:2-Finger Gripper3-Finger GripperFT-150/300 SensorNote: If you need extra guidance, you can get in touch with a Robotiq Application Engineer.
You can find information on our support page. 2D drawings are available in manuals and CAD can be downloaded.https://robotiq.com/support
2-Finger Gripper
3-Finger Gripper
FT-150/300 Sensor
