Hello Matthew,
Robotiq have made 2 applications package that could help you. The first one is to use the ethernet port to capture the data from the FT300 to an external PC. The second package will help you to stream the data to a csv file. With this data you will be able to create a graph on a spreadsheet.
You can find the application package here :
https://blog.robotiq.com/data-logging
https://blog.robotiq.com/streaming-data-from-ft-sensor
Regards,
PE_Germain
I am looking to use a FT300 sensor with a UR10 to monitor the force on a a defined axis over a number of cycles on a part which is to be tested and represent this as a graph of some sort. What would be the way to go about this?
Matthew Ruddock
