Hello @Razvan, I opened a support ticket to help you with that.
 David_Levasseur
                    David_Levasseur
                It worked well with a different robot but never with this one. Therefore, there must be a problem with the robot.
 Guillaume_Charron
                    Guillaume_Charron
                @Chad354
I opened a support ticket so we can investigate your issue. You should have received an email on that matter.
 Guillaume_Charron
                    Guillaume_Charron
                A manual recalibration of the robot arm has solved Chad's issue.
         Chad354
                    Chad354
We are trying to calibrate a UR5 with a Robotiq wrist camera, every time we do this process, the last photos are full of red dots, everything is well lit, the board is visible, we did it 20 times, and every time we get this error code - [ CS- 15 ], what are we doing wrong ? We tried with the latest software, we tried downgrading but no luck.
Thank you for help.
