My 3-Finger Adaptive Robotiq Gripper can not be activated normally. It is unclear what has caused this situation.Finger B and C only move a bit when I try to activate the gripper, then it ignores all the commands until I replugged the power cable.I have tried activating the gripper both from the ROS interface and user interface, neither came out success, so I am contacting you to look for a solution.
Hello @cassie, We have a support ticket with you for helping troubleshooting this. I will post the result of the investigation here later.
Thanks to the additional info provided by @cassie, it turned out the external power supply was not providing enough current. The use of the appropriate power supply fixed the issue.
