Hi, You seem to have a powering \ wiring issue, the communication chip not ready message is probably caused by power loss. Blue LED off = no power. Could you check integrity of your wiring and of Gripper connector ? Could you also check that your power supply is a stable and reliable 24V DC supply ? There could also be an issue with grounding if it's not done. Thanks!
Robotiq_Customer
Hello there, I'm having an issue with my 2-finger 85 gripper. I am using the PC software to activate and control it. Every once in a while, when I go to activate the gripper, the connection would cut out very briefly and an error message would flash for less than a second "Minor Fault: The communication chip is not ready," I had to use the slow-motion camera in my phone to capture the message. The blue light on the gripper would turn off for about a second and then turn back on. I am powering the gripper with a 2.5A AC to DC adapter and I have tried two ATC USB adapters with the same result. Do you have any ideas what it could be? Best regards,
