Hello all,I would like to ask if it is possible to increase the torque linearly according to how much the robot tool flange rotates. To give an example, torque increase linearly from 0 to 2Nm in a 90 degrees rotation.thank you in advance.
@agiakos I'm not sure but I would try something like this: Check initial position and initiate a 1 degree rotationThen in a thread: Compare with current position to get the rotation variation. Based on your example I would then take this variation and divide it by 45 (90 degree/45=2NM) and assign it to a "required_torque" variableIf the current torque is below the required_torque, then rotate 1 degree. Hope that help
Hello all,
