- The Insertion node has been added (read more below) - The Find Surface node has been added (read more below)
Bug Fixes
- Bug fix for path recorded without moving the robot - Warning message is displayed when robot program's play button is pressed more than once - Fix for the double definition of functions when conflicting Skills are installed - Warning message is displayed when obsolete Skills are installed
Insertion node
The Force Torque Sensor URCap Package includes the Insertion node, which can be used to perform spiral, rotational and linear movements to insert objects in holes or bores, or to make contact with a surface. It is an essential integration resource for streamlining robot programs in the framework of precise assembly applications.
When the task is performed by a human operator, the operator's fingers provide valuable feedback through the sense of touch, thus allowing the human to detect any resistance when trying to insert a pin in a hole, for instance. To a certain extent, the FT Sensor gives that kind of sensitivity to the end effector.
Below are the different options available when inserting an Insertion parent node.
Spiral Following a contact established between the object grasped by the end effector (or the end effector itself) and the corresponding mating part or surface, a spiral motion is engaged on a specific plane to find the path of least resistance according to the direction, speed, force, radius increment per turn and maximum radius parameters set by the user.
Rotational Following a contact established between the object grasped by the end effector (or the end effector itself) and the corresponding mating part or surface, a spiral motion is engaged around a specific axis to find the path of least resistance according to the direction, speed, force, maximum torque and maximum rotation angle parameters set by the user.
Linear Following the successful spiral, rotational or fortuitous location of a mating hole or bore, a linear motion is engaged at a certain speed until the force threshold or maximum travel distance is reached.
Find Surface node
The Find Surface node is a great tool for machine tending and various other applications that require repeated accurate positioning of objects.
The default parameters of the function allow for a versatile demo or a quick test of the features while the advanced parameters make it a more customizable asset, given the possibility to change the following:
- Motion speed - Maximum travel distance - Force threshold
The latter two are known as stop conditions. Ticking their corresponding box creates child nodes packaged as If statements. The user can define the next course of action in the program, e.g. a gripper open command after the force threshold is reached, or a move to the initial position after travelling to the maximum distance.
Contact support@robotiq.com should you have technical questions regarding the FT 300 Sensor and its software.
On August 8, 2018, Robotiq launched version 1.5.0 of its FT 300 Force Torque Sensor URCap (UCS-1.5.0) for CB-Series Universal Robots (PolyScope 3.6).
It boasts the same reliability, and includes new application-oriented features.
Browse to the support product page of the FT Sensor to download the URCap.
Features
- The Insertion node has been added (read more below)- The Find Surface node has been added (read more below)
Bug Fixes
- Bug fix for path recorded without moving the robot- Warning message is displayed when robot program's play button is pressed more than once
Insertion node
Spiral
Rotational
Linear
Find Surface node
- Motion speed
- Force threshold
Best Regards,
