Annick_Mottard
Hi Pros!
On August 1st, Robotiq released version 1.3.1 of its Robotiq Grippers URCap (UCG-1.3.1).
Please find all pertaining information below.
Features
- The interface is compatible with PolyScope 5.0
- The interface is compatible with PolyScope 3.6 (NOT compatible with PolyScope 3.5)
- rq_gripper_led_on() and rq_gripper_led_off() functions have been implemented for LED control
Bug fixes
- Node names are no longer truncated
- Grip Check is functional when PolyScope is set in a language other than English
- Grip Check's If child node name remains the same upon program reload
Cable-to-wrist power up procedure
Input/Output
- Tap the I/O tab at the top of the screen
- Select the Internal menu in the navigation pane on the left
- In the Tool Output section, move the slider to the 24V setting
Enable Tool
- Tap the Installation tab at the top of the screen
- Select the General menu in the navigation pane on the left
- Select the Tool submenu
- Tap the Enable button
- Use default settings for Baud Rate (115200), Parity (None), Stop Bits (One)
Let us know if you have questions or comments.
Cheers!
