Alright, so the Robotiq products are not certified yet. However, we can estimate the IP ratings if we do compare with the IP certification criteria.
- The grippers (2-F-85 and 2-F-140) are estimated at IP 54.
- The sensor FT-300 is estimated at IP 40. If you need a higher rating, Robotiq R&D team will be glad to design a special cover to bring that rating up.
- The FT-150 is at IP 67.
- The 3-F is a particular case as the casing is at IP 54 but it does have external gears so nothing certain about this one. Robotiq also has designed a glove allowing to increase this rating even more.
For more info about the IP ratings, see this blog post.
Hope this helps.
Catherine_Bernier
Annick_Mottard
Anyone knows the IP rating of the Robotiq Grippers?
