@ritchiepham I will assume you are using Robotiq FT-300 sensor (correct me if it is not the case). What threshold are you using for your detection? With a static robot you should stay around 1N for example, moving will need to go higher. Anything that can induce some forces during the movement? Cables from your tooling for example?
David_Gariepy
I am experiencing force spikes when the robot is moving. I am using a program that has the robot travel in one direction until it detects a certain force. At that time, the robot will travel to another waypoint. The robot often encounters situations where it will act as if it felt a force even though the sensor is zeroed and nothing is touching the robot. I am actively monitoring the forces of the robot in all axes and can see these spikes.
Any help please?
