@poiujkmmmm it is possible to do so, I suggest you read the section 6.2 of the instruction manual about object_location pose. You will findthat object_location is a variable pose (p[x,y,z,rx,ry,rz]) that will point the part you have teached with position and orientation. The manual also contains some examples on how to use the variable.
We want to check PCB board by your Camera. And PCB have different position and different degree in work plane. I know your Camera can detect it in different position and degree on work plane, but I want to know how many distance and degree have changed in every time. Can Camera give us a detail value (position value)? If you know that, please tell me detail. If you can send picture to teach me , that is better. Please see the attachment about problem.
