Hi @kaankoyun,
What is the weight of a sheet?
You could probably use a FT 300 to detect the presence of more than one sheet.
What do you mean by 0.5 inches diameter and around 1.5 inches length double sheet pick up detector? Is that the size of the sheet or the detector you are looking for?
David_Gariepy
Hi , I use UR i our facility , we work with sheet metal and I need to use detector to minimize error , because I use magnetic gripper which I can make stronger for accuracy and speed but it gives me hard time while picking up the piece and picks up double piece or more than double , I need small maybe 0.5 inches diameter and around 1.5 inches length double sheet pick up detector would perfectly work for me .
I would like to have a recommendation from you
thank you
