Have you tried removing all the IO blocks except the safety and power blocks to see if it stops? I’ve never seen an issue like this before.
One more ore dumb question....have you tried rebooting the robot?
All I/O blocks are removed but the problem is still here, like you can see in this short movie : https://www.dropbox.com/s/4f9jfeogdzflb34/IMG_2359.MOV?dl=0
I've made my short program following these few steps, and I've made tests between each of them:
- made a simple move -> OK
- add I/O -> OK
- add ModBus -> NOK
I'll try to restart from the beginning but I'll add ModBus before I/O.
And Yes I've reboot the robots, they where OFF for 2 days. When I try them this morning the problem was still here.
I'm also in touch with a technical support, but for now, no solutions have been found.
Can you post up your program?
Here is a link to the UR documentation on the modbus registers on the robot and how to use them to access certain features that @PierreDenis mentioned.
https://www.universal-robots.com/how-tos-and-faqs/how-to/ur-how-tos/modbus-server-16377/
These can be really handy, especially when you have multiple robots in a cell as one robot can see what the status of the inputs are on another one. Very handy when you have more I/O on one robot than you have capacity built-in and another with excess I/O. They can effectively use each other as modbus expansion systems.
Hi pros,
I was programming 2 UR10, and one of theme use digitals I/O.
The problem here, is that all outputs stay at high level and I can't bring theme down.
If I touch an output it go low for around 0.1 second before go back at high level.
I've tried to force the outputs to low levels using the installation tab and choosing the "low when not running" parameter on all outputs. With this parameters up, we can see that something is trying to put the outputs at high level just before the parameter bring them down.
I've disconnected the 2-finger gripper (USB + alim), the network between the 2 UR, and every thing on I/O ports.
The 2 UR10 are on CB3.1 and up to date.
Here a short movie with the I/O tab : https://www.dropbox.com/s/slj8vhkblutwlhk/IMG_2358%5B1%5D.MOV?dl=0
Thanks for your responses.
