Hallo,The UR10 I am working with does not start since the day before yesterday.When I try to start it, the "Universal Robots" sign shows up, after that it shows "DVI-No Signal" and "Scanning Port-No Signal".The last time I worked with the UR10 I tried the "continous Logging"-Software without any problem.Is there any possibility to get the UR10 started again without changing the the motherboard?Kind regards
Sounds like the motherboard went out honestly. I’ve only seen that once before, on a UR10 as well. I’d contact your distributor.
Hallo,
Kind regards
