bcastets
I don t have the answer to your question but I would recommend to check this post:
https://dof.robotiq.com/discussion/1962/programming-options-ur16e-2f-85#latest
There are several way to communicate with a gripper connected to a UR robot. You go through client interface but some people go through UR RS485 URCAP or communicate directly with the robotiq gripper URCAP server.
Communicating directly with URCAP server looks interesting. I never tried it but it is probably the best.
The easiest solution is to connect the gripper directly to your PC.
