dannyhefdannyhef Unconfirmed Posts: 3 Apprentice
I'm wondering if it is possible the get the joint positions (x,y,z) and not just the angles.
Does anybody know how to get them?
Dan
  • jelmsjelms Posts: 21 Apprentice
    I think what you are asking for is Cartesian coordinates for each joint. There is a way to get the TCP in xyz. I don't think there is a built in way to request them. Computing the forward kinematic transform for each intermediate joints position in base coordinates using the specific robot parameters. You can probably use pose_trans() if you need to compute it in a script.
    I am curious why you would need that. Care to share?
    I know that the elbow position is available on the RTDE interface but I cannot find any other location where it would be available via script.  I would submit your use case as a feature request to UR.  They may be able to add that to the script manual in future releases if you have a compelling use case or may be able to help you calculcate it.
  • dannyhefdannyhef Unconfirmed Posts: 3 Apprentice
    Thanks guys for your anwsers. I will forward my use use case to UR and maybe I can figure something with the rtde interface or to calculate the positions via manual rotation matrices. I need the positions because I'm working right now on my master thesis and I'm implementing dynamic safety zones depending on the nearest position of any joint or TCP to a human.
    I'll keep you updated
    Hey Matthew, you are totally right. That's all what I need, I have the Base, I have the Elbow via RTDE and I have the TCP. So now I have to work with the RTDE interface. Thanks a lot for your help.
    I tried the control loop example of the rtde from UR but it tells me that a variable is already in use and I have no idea why. The problem was also stated on zacobria but with no solution. Any ideas?
    Not sure, do you have any URCaps installed on the robot?  Try taking out the input map, just monitor the RTDE outputs. That is the example i used originally to build our first RTDE listener off of. We did not inject anything into the robot through RTDE so we only listened to what it was outputting.
