[Deleted User]
Hi @agiakos
  1. Yes, you can communicate with Labview to the Robot controller and FT Sensor  using Ethernet to retrieve or send datas. Information can be find here for the UR: https://www.universal-robots.com/how-tos-and-faqs/how-to/ur-how-tos/ethernet-socket-communication-via-urscript-15678/
  2. To communicate with the FT sensor force via Ethernet you can use the Modbus RTU Serial communication or can access the Data stream on TCP port 63351 via the UR Controller: https://robotiq.com/support/ft-300-force-torque-sensor/downloads-instruction-manual (Ref. Section 4.5: Serial Communication)
  3. You can import the TCP position from the Controller and force feedback to create a LabView Program. Look at to this post presenting how to send/collect datas  to a device connected in TCP/IP in Labview: https://forums.ni.com/t5/LabVIEW/TCP-IP-connection-between-PC-and-UR5-Universal-Robot/td-p/3153351
Don't hesitate if you have any questions or concerns,
[Deleted User]
David_Gouffe
