I have used the Airgate to VNC in to the UR. It is very easy to setup and connect too whether it be through your network or a mobile sim card. Never ran into any problems while using it.
                    Daniel
                Hi, I made backup of USB-drive using ImageUSB and I was able to boot form a cloned USB3 drive. After some testing I was able to install and run x11vnc on a CB3.1 robot.
I've been working on a VNC solution for the robots, thought I could as well share it with you guys:
- Connect the robot to the internet and make sure it has an IP adress configured (DHCP/Static).
 - Connect to the SSH shell using putty (user:root / pass:easybot)
 - Run "apt-get update" and "apt-get install x11vnc". (I didn't want to break anything, so I didn't do an upgrade!).
 - Run "x11vnc -storepasswd YOURPASSWORD /etc/x11vnc.pass"
 - Edit ~/xsession as PierreOlivier_Proulx said, adding: "/usr/bin/x11vnc -xkb -noxrecord -noxfixes -noxdamage -display :0 -rfbauth /etc/x11vnc.pass -rfbport 5900 -forever -auth root -bg -o /var/log/x11vnc.log" at the beginning of the file (after the #!/bin/bash).This starts a x11 VNC server, with all the necessary options to make it run on background forever.
Hope this helps some of you!
                Hi, I just stumbled into this thread and got vnc working with these steps. The only problem i'm having is getting it to auto start on power on.[Deleted User] said:I've been working on a VNC solution for the robots, thought I could as well share it with you guys:
Any Ideas?
Thanks,
Brian.
                @thewave Where is the vnc command located in the xsession file. Can you post it?
Here is my xsession filePierreOlivier_Proulx said:@thewave Where is the vnc command located in the xsession file. Can you post it?
#!/bin/bash
/usr/bin/x11vnc -xkb -noxrecord -nofixes -noxdamage -display :0 -rfbauth /etc/x11vnc.pass -rfbport 5900 -forever -auth root -bg -o /var/log/x11vnc.log
export DISPLAY=:0
xmodmap -e 'clear Lock' \
        -e 'keycode 0x42 = Control_L' \
        -e 'add Control  = Control_L' \
        -e 'keycode 0x16 = BackSpace' \
        -e 'keycode 0x6B = Delete'
xset s off
xset -dpms
xsetroot -solid black
loopval=0
while test x$loopval != x131;
do
  source /root/run_gui.sh
  if test x$loopval == x10; then
    touch /tmp/.reboot
    exit 10
  else
    nice $RUN_GUI
  fi
  loopval=$?
done
                if you put the export DISPLAY above the x11vnc command, does it works?
Its working now. It was my -nofixes option typo in the xsessions file.PierreOlivier_Proulx said:if you put the export DISPLAY above the x11vnc command, does it works?
What happens when you SSH into it?
Ohh . same thing ,
                Hi guys,
Great news! No need to fiddle with the console and bash code to remotely control your robot anymore. With Remote Access, you can access the teach pendant directly in your web browser. On top of that, you can plug in webcams in the controller and see your robotic cell while jogging the robot.
Try it out on the demo robot here.
Do you know something about the warranty of Universal Robots when "third party" software is gonna be installed?yuvarajoo said:Hi,I have packaged an urmagic file for easy installation. Just extract to usb to install the magic file. This is modified from another person.
Best regards.
Does anyone know if this still works? its telling me that the ftp.dk.debian.org files arent found
                Where is the file attached at?
                I linked it. The attachment did not work.
What do i do after install?
                You connect to the vnc server with a vnc client. The port is 5900. You will have to enter the robot password which is easybot by default.
                right
its not letting me connect.
                Have you inserted the usb flash drive in the controller? Are you sure you are on the same subnet as the robot. Did you enter the pass word?
                Then I don't know. Maybe you can check on the urplus forum. https://forum.universal-robots.com/t/remote-desktop-to-the-controller-ui/3826.
                    mhowe
                    MarkEGuida
                    David_Gariepy
                    yuvarajoo
                    David_Gouffe
By installing VNC server it would be possible to remote control and troubleshoot a robot from office PC, tablet or smart phone... It could be quite useful.
