Info Command Obtain hardware information. Example - Info
#Include "Robotiq_FS.pcs"
Sub Main
Dim Opt As Variant
Call Robotiq_FS("Info", Opt) 'Get FT300 Sensor Information
PrintMsg "Firmware Ver.: " & Opt(0)
PrintMsg "Serial No.: " & Opt(1)
PrintMsg "Production Year: " & Opt(2)
End Sub
Start_Stream Command Start data streaming. Example - Start_Stream
Sub Main
Dim Opt As Variant
Call Robotiq_FS("Start_Stream", Opt) 'Start Streaming
End Sub
Stop_Stream Command Stop data streaming. Example - Stop_Stream
Sub Main
Dim Opt As Variant
Call Robotiq_FS("Stop_Stream", Opt) 'Start Streaming
End Sub
Get_Data Command Get FT300 sensor data. Example - Get_Data
Sub Main
Dim Opt As Variant
Call Robotiq_FS("Get_Data", Opt) 'Get Force Data
PrintMsg "Fx: " & Opt(0)
PrintMsg "Fy: " & Opt(1)
PrintMsg "Fz: " & Opt(2)
PrintMsg "Mx: " & Opt(3)
PrintMsg "My: " & Opt(4)
PrintMsg "Mz: " & Opt(5)
End Sub
Application Example: Force Data HMI
Force.pn1 Code:
#Include raw
Dim Option As Variant 'Return Variable
Dim stream_flag As Integer
Dim zero_fx As Single
Dim zero_fy As Single
Dim zero_fz As Single
Dim zero_mx As Single
Dim zero_my As Single
Dim zero_mz As Single
Sub Panel_INITIALIZE()
'Check if Connection has been made before trying to connect
If Comm.State(COM_PORT_FT) = 1 Then
'Get Sensor HW Information
Call Robotiq_FS("Stop_Stream", Option)
Call Robotiq_FS("Info", Option)
'Get Data
Label10.Caption = Option(0)
Label11.Caption = Option(1)
Label12.Caption = Option(2)
PBSTART.Active = 3 'Enable Start Button
PLCOMSTATE.FG = &h00FF00
Else
'Terminate HMI Panel Program
PrintMsg "Connection Failed... Exit Panel and Retry"
PLCOMSTATE.FG = &h0000FF
Exit Sub
End If
End Sub
Sub PBSTART_CLICKED()
'Start Streamming
Call Robotiq_FS("Start_Stream", Option)
stream_flag = 1 'Turn Stream Flag -> ON
PBSTOP.Active = 3
PBSTART.Active = 1
PBZERO.Active = 3
End Sub
Sub PBSTOP_CLICKED()
'Stop Streaming
stream_flag = 0 'Turn Stream Flag -> OFF
PBSTOP.Active = 1
PBSTART.Active = 3
PBZERO.Active = 1
End Sub
Sub TIMER1_TIMER()
If stream_flag = 1 Then
'Get Data
Call Robotiq_FS("GetData", Option)
Label18.Caption = SprintF("%-08.3f", Option(0) - zero_fx)
Label17.Caption = SprintF("%-08.3f", Option(1) - zero_fy)
Label16.Caption = SprintF("%-08.3f", Option(2) - zero_fz)
Label15.Caption = SprintF("%-08.3f", Option(3) - zero_mx)
Label14.Caption = SprintF("%-08.3f", Option(4) - zero_my)
Label13.Caption = SprintF("%-08.3f", Option(5) - zero_mz)
End If
End Sub
Sub PBZERO_CLICKED()
'Zero calibration
zero_fx = Option(0)
zero_fy = Option(1)
zero_fz = Option(2)
zero_mx = Option(3)
zero_my = Option(4)
zero_mz = Option(5)
End If
End Sub
Hey there,
So here are some command reference and example so that you can program your Robotiq FT sensor on a Denso RC8 controller.
Info Command
Example - Info
Stop_Stream Command
Get_Data Command
Example - Get_Data
Force.pn1 Code:
Hope this helps.
