Hi @Sergio_Rendon,
The camera cannot count the number of object or features. Also, it is not possible to differentiate many objects with only 1 camera locate. You'll need a camera locate for each part. If the parts are similar, you'll need to search for the part with the most feature first. Then if you don't find any, look for a part with less feature and so on. If you could share some pictures of your parts we might be able to give you some tips.
David_Gariepy
Im working on an application that needs the detection of a part with a lot of holes in it, i use the camera locate node and the camera detects all the circles in the part is there a way to differentiate each part by the number of holes in it?
