What is a good way to make a UR10 robot wait for a status flag before continuing? I need to monitor two digital inputs and based on their status, set a flag for "Conveyor_Ready" so the robot can do it's pallet function. Right now, I have the inputs checked in a subroutine that is called before the pallet routine executes. The first time, I tried a loop that was supposed to continue calling the subroutine to check the digital inputs, but I got an error saying the robot was idle too long waiting for an instruction.Basically, I want to haveIF Digital_In_0 == FALSE AND Digital_In_1 == TRUEConveyor_Ready := TRUEIf Conveyor_Ready == FALSEWAITIF Conveyor_Ready == TRUEPallet
Just use wait and in the fx field put the input you want to wait for. So pseudocodewait Conveyor_ReadyNo need for the if statements.
I have more than a single input to monitor, so I have a subroutine to set the flag “conveyor_ready”now this is morphing into something more because the program faults out when it gets to this point, stating invalid set points. The log indicates the program contains motions that are not ramped correctly down. So I tried stopj(120) and also telling the previous waypoint to stop instead of blend.
You could monitor both inputs in the wait statement. Try changing your stop command to stopj(8) as that is about the maximum acceleration, it’s in radians per second squared, not degrees.
WAIT
Pallet
