Hello @T800_412,
Could you explain what you want to do exactly?
The feature point of the snapshot position is used as a reference and should not be used in a program. The feature point could be completely different than the snapshot position.
If you need to use this position in your program, you can create another one.
David_Gariepy
I am having some difficulty with a snapshot position variable having the wrong value, and I do not know how it changed or how to correct it.
1. created a feature point for the cam locate function. Made that feature variable. It is called template_wheel
2. calibrated the wrist camera to locate a grinding wheel at this position.
3. Using the move tab, the TCP will move to the correct point every time using Automatic. (for discussion, it is at p[0.050,0.050,0.200,0,0,0])
4. When the program is running, the variables window shows the Y value for this pose way off ( p[0.040,-0.730,0.100,0,0,0]
The pose_add command is search_pos:= pose_add(template_wheel,snap_off_pos) and the TCP is sent out of the intended position.
What is wrong and how do I fix it?
