Having a hard time setting up force command to push a piece of sheet metal against pins to square it up, to be pressed
Make sure you reduce the speed at which each of the compliant axes can change. They are set at the top end for speed and rotation, we generally reduce to 15-20 deg/sec for the linear motion and 5-10 deg/sec for the rotational elements. Find this makes the force wizard much better
