@bsawlor would that be on a UR robot, like starting scripts or command with a PLC? Or would it be on a completely different robot where you want to do the equivalent of the UR functions?
@bsawlor for the FT-300 you can read the data directly on a TCP socket, find the info in section 4.5 of your manual.
For the Gripper the easiest way to do what you want to do would be to start scripts on your UR that runs our functions, see the functions list in section 4.9.4 of your manual.
Is it possible to use the functions for the gripper and even the FTS over TCP or using socket commands? I suspect it's possible, but I haven't seen a guide confirming this.
