Hello.I am trying to compile the ros packages suggested by @carlosjoserg However, I am having compilation erros and I am not sure if this action messages is correct... The problem s with the goal message Robotiq2FCommand command. Is it correct? do I have to specify a dependency in the CMakelists?https://github.com/beta-robots/robotiq/blob/new_2_finger_models/robotiq_2f_controllers/action/Robotiq2FCommand.action
Hi @carofide I didn't go that path, since I preferred to use the already defined GripperCommandAction ni control_msgs, as you can also see configured in this example.Any way, it should be compiling smoothly, what errors are you having?
Hello.
