I’m trying to use the object_found function to adjust a frame on a universal robot (UR10 Version 3.4.2.65). For some reason the accuracy on the rotation is terrible. Attached is a video of it in action, below is the code. The first 3 marks in the video are within the camera subroutine. The next 2 marks are done by using a frame adjusted with the difference between two object_found positions (pos_found – pos_original). Is there any fix for this? Do I have to do something special when subtracting rotation values found by object_found? I know it's not a vision target issue because the 3 vision points are ok Note, the vision system is using the Automatic Method (not parametric method) so that the T within the circle will keep the orientation accurate. Also, the snapshot position is perpendicular to the targetUF1 = plane used as a user frame Program Robot Program MoveJ TEST_var Camera Locate MoveL Waypoint_1 Waypoint_2 Waypoint_4 Waypoint_5 Waypoint_6 Waypoint_7 Waypoint_8 frame=UF1_var pos_found≔object_location x_adjust=pos_found[0]-pos_original[0] y_adjust=pos_found[1]-pos_original[1] r_adjust=pos_found[5]-pos_original[5] UF1[0]=pos_original[0]+x_adjust UF1[1]=pos_original[1]+y_adjust UF1[5]=pos_original[5]+r_adjust frame_post=UF1_var MoveL 'With UF1 as the frame the positions are based off of Waypoint_9 Waypoint_10 Waypoint_11 Waypoint_12 Waypoint_13
@nick what is the detection threshold you are using? Could you check in the installation tab, live image of the camera, and see how your model is matched to the real part?@Vincent_Paquin can you advise?
@nick, @Etienne_Samson If I understand correctly, the problem here is that the frame is not fully adjusted. The current adjustment is only a 2D adjustment while in reality it is a 3d problem. The rotation is assumed to be only around the z-axis, but it is a 3d rotation. The x, y and z component of the rotation axis must be taken in account as well as the z component of the translation. In short, the 6 components of the transformation must be used.I hope this helps.
@etienne my detection threshold is 85%, but it's not getting a false detection. If it was getting a false detection then the first 3 marks would have been off as well. The issue it seems is with my math it seems because I'm not handling the rotation vectors correctlyThank you @Vincent, that helped me troubleshoot this a bit and now I know the better question to ask. So basically what I was doing was subtracting the difference between the pos_found and pos_original which gave me a good x,y,z offset but I can't do this with the rx,ry,rz it seems because they're rotation vectors. I figure I have to use pose_trans() but I couldn't get it to work right; below is the simplified version of my code, I just need to know how to properly offset the frame's rotation. FYI I also tried converting my rotation vectors to RPY and then doing the math but that didn't work, though I may have done that incorrectlyThe goal is to offset UF1 by the offset of pos_found relative to pos_original. Thus if pos_found is 30mm up in the x direction and 15% degrees rotated (compared to pos_original) then UF1 should be adjusted that amount. pos1 is the backup of UF1pos_original is the reference position Robot Program UF1=pos1 MoveJ TEST_var 'My snapshot position Camera Locate MoveL Waypoint_1 Waypoint_2 Waypoint_3 Waypoint_4 Waypoint_5 Waypoint_6 Waypoint_7 Waypoint_8 frame=UF1_var pos_found≔object_location pos2=pose_sub(pos_found,pos_original) UF1=pose_add(pos1,pos2) frame_post=UF1_var MoveL 'motions are relative to UF1 Waypoint_9 Waypoint_10 Waypoint_11 Waypoint_12 Waypoint_13
Figured out an alternative solution to my problem. Though if possible I'd still like to understand how to do the above.
Program
Robot Program
MoveJ
TEST_var
Camera Locate
MoveL
Waypoint_1
Waypoint_2
Waypoint_4
Waypoint_5
Waypoint_6
Waypoint_7
Waypoint_8
frame=UF1_var
frame_post=UF1_var
Waypoint_9
Waypoint_10
Waypoint_11
Waypoint_12
Waypoint_13
