Hello @anant
Here is a post that explains how to integrate the Robotiq Gripper with a Denso controller it also contains a link to download the driver.
Here is a post with an example of programming the Robotiq Gripper with a Denso controller
Let us know if there is anything else we can help you with.
David_Gariepy said:Hello @anant
Dear Team,
We are unable to establish the communication between Robotiq Gripper and RC8 Controller for Denso Robot.
Note: As per mentioned in manual The ROBOTIQ gripper connects to the DENSO RC8 controller via the RS-232 port.
You will need to use a RS-485 to RS-232 converter between the ROBOTIQ gripper and the RC8 Controller.
The Gripper LED is glowing RED whenever connected to RC8 Controller via RS-485 to RS-232 converter.
Require your technical assistance as the customer is very much disappointed with the support.
Note: We are able to operate the Gripper via RUI.
Await your reply.
Regards
Anant Naik
David_Gariepy
Dear Team,
We require assistance in integrating Robotiq Gripper 2F140 Gripper with Denso Robot model #: ‘VP-6242M’.
· Installation/programming procedure of gripper with Denso robot.
· Electrical Connection.
· Gripper Communication connection wrt Denso Robot.
· Gripper Control.
Driver Packages
Await your reply.
Regards
Anant
