Samuel_Bouchard
@jproberge would you have a hint on this one?
Hello @mariaevinne !
To be honest, it's been years since I've worked with robotiq's 3-fingers gripper in rviz, so I'm not sure I'll be able to help here.
But, from what I can remember, Robotiq does not have an official urdf / xacro file for their S-Model gripper on their official Github. Rather, it seems they only have a urdf / xacro macro for the C-Model. From what I can remember, in the past, I used to follow guidelines from this link: https://bitbucket.org/osrf/drcsim/pull-requests/522/tuning-robotiq-hand-grasping/diff , which uses the (simplified) atlas description of the S-Model, the source of that is located here: https://bitbucket.org/osrf/drcsim/src/194be8500fef81593f79607a21ee2badd9700a0e/atlas_description/robots/?at=default , it was originally developed as part of the DRC simulation (so now outdated). I remember we were able to open and close the gripper using that model.
But as you will see, it's a very simplified model, and depending on the ros version you're using and your expectations about the accuracy of the gripper's modeling in rviz, you might have to update the procedure mentioned above. Other people could have developed more advanced models / functionality for simulating this gripper, but I don't know where / if that would be available.
Hope that could still provide a little help!
Regards
