I have not seen this exact problem using the dashboard server, we send commands remotely to the robots including the play command. I do know in the latest UR update that came out yesterday they fixed something with sending play over the dashboard server when the robot is safeguard stopped, maybe it also addresses this issue, worth a try. This is software version 3.4.3.77, here are the release notes.
JacobBom
I have a problem of integration. We are using two UR10 piloted by a Siemens automate and Dashboard connection.
We call the program then we send the start command.
Our first problem was that we had to send the start command twice. We tried to delay the sending of the start command and it worked quite fine then.
But now, one of the two cobot doesn't want to start at all. We tried several things but the only way to launch the program is by the play button on the screen of the cobot.
The program is getting bigger but is not finished so it can be a real problem...
Did anyone have this problem before?
Does anyone have an idea or a solution to this problem?
