We use a standard naming convention of CustomerName_ProjectName_Default for the default program that loads automatically. We then store our versioned programs in an archive folder. In that folder we use semantic versioning with major.minor.bugFix. We use the naming convention of CustomerName_ProjectName-vx.y.z
The CustomerName and ProjectName we abbreviate so that it's not too long, generally 3-5 letters for the customer and project names.
In the before start section of the program we use a variable named VERSION to store the current version number in so that appears near the top of the variables list. Helps us to identify quickly with customers if they are running the correct version of the program.
We do USB magic file backups at the end of each day or programming and sometimes more frequently depending on what's going on. We also have the ability to backup programs to AWS remotely so we can grab files at anytime to look at.
Samuel_Bouchard
Hi Matt, thanks for sharing the tips! I am sure that these aspects are even more important for a business like yours.
Samuel_Bouchard
Thanks for your input @Colin and @Luis, much appreciated!
I know this is an old post but wanted to update with some of the new features that we have released to the public. You can now use the Hirebotics mobile app to automatically and securely create versioned backups of all files on the robot. You can even restore to an older version directly from the mobile app. You do not need to keep named versions on the robot anymore. Every time the file is saved we create a secure version of it in the cloud. The data is only yours and you can control who has access to that data. Files can be shared using time sensitive, secure links directly from the app. If you need to send files to UR or the distributor to help with an issue or warranty claim you can do it right from the phone. There is no hardware to purchase, this all runs entirely on the robot natively. You can find more information on it at https://www.hirebotics.com/app
Hi Pros, I got asked the following and would like your input.
