Hi @antbiv
So far, I haven't seen any custom implementation of the 2 Finger Gripper in Gazebo, and moreover, in the ROS-i repos, I couldn't find and URDF of the new gripper model 2f-85. So I created one that you can find it in our fork&branch: https://github.com/beta-robots/robotiq/tree/new_2_finger_models/robotiq_2f_model (The idea is to contribute it back to the ROS-i repos after I test it more).
If you don't need the adaptivity-mode of the gripper in simulation (which is not easy, btw), then you can use the gazebo_ros_control plugin. The plugin works better with one single instance of an URDF. So my suggestion is for you to assembly one single URDF with UR5+Robotiq 2F-85, and then add the plugin to that. Something like:
<?xml version="1.0"?>
<robot xmlns:xacro="http://ros.org/wiki/xacro" name="assembled_robot">
<!-- THE ROBOT -->
<link name="world" />
<!-- UR from ROS-i repos -->
<xacro:include filename="$(find ur_description)/urdf/ur10.urdf.xacro" />
<joint name="world_joint" type="fixed">
<parent link="world" />
<child link = "simple_arm_base_link" />
<origin xyz="0.0 0.0 0.0" rpy="0.0 0.0 0.0" />
</joint>
<xacro:ur10_robot prefix="simple_arm_" joint_limited="false" precise_collision="false"/>
<!-- Robotiq from Beta Robots fork-->
<xacro:include filename="$(find robotiq_2f_model)/model/robotiq_2f_85.urdf.xacro" />
<xacro:robotiq_2f_85 name="simple_gripper" parent="simple_arm_tool0" precise_collision="false" adaptive_transmission="false">
<origin xyz="0 0 0" rpy="0 0 1.5708" />
</xacro:robotiq_2f_85>
<!-- Plugin -->
<plugin name="ros_control" filename="libgazebo_ros_control.so" />
</robot>
Then you need to configure, load and start any compatible ros-controller, as you'd normally do with a real robot or UR5 you say you have. If you need further details on how to do that, let me know.
Best,
Carlos
I need to have in ROS Gazebo and MoveIt an UR5 robot who has the Robotiq 2 Finger Gripper(85) in the simulation models. At the moment all I have is the UR5 model only for simulations. How do I add the gripper to this model
