What's the material @Grady_Turner?
When we did sheetmetal that was ferrous we used destacking magnets to seperate the sheets. Here is a link to some magnets as well as air knives for separating non-ferrous sheets.
Does anyone have experience picking sheet metal from a stack using vacuum. In this case there are separator sheets, but the problem is that the pieces like to stick together because all of the air in between has been pressed out. We have tried several different techniques of lifting off, but every time one or more pieces in the stack are moved out of position.
Any advice would be appreciated.
