HiI have created I robot program with movej and I would like to reuse that program with a different robot coordinate system orientation. I mean, the robot base bolt pattern will be rotated by 30 deg around the Z axis.Is it possible to use the mounting robot tab and change the robot by 30 deg and apply this new position to the existing program?Any suggestion?Thanks
Hi @SteveBoulay You should compensate the 30 degrees of mounting with the 30 degrees of joint base at each waypoints. It is posible add or substract this value inside menu "Edit pose".I hope this helps
Hi
Any suggestion?
Thanks
