@wileydavis
You can do this a couple of ways, create a variable and then use this as a waypoint or just use script to do the move.
newWaypoint = pose_trans(Tool,p[0,0,.0254,0,0,0])
Movel
newWaypoint
The pose trans function is transposing the current tool position by using the Tool pose, you can't type that you'd have to select it from the pose drop down menu. If you want to type it it would be something like this newWaypoint = pose_trans(get_actual_tcp_pose(),p[0,0,.0254,0,0,0]) If you want to do it all programmatically then it would simply become something like thismovel(pose_trans(get_actual_tcp_pose(),p[0,0,.0254,0,0,0]),a=1.2,v=.25)Where a and v are the acceleration and velocity in m/s/s and m/s respectively. The the other way which I use occasionally is to use a relative waypoint. I don't like the control that this gives you or rather lack in my opinion but it's relatively easy to set up and builds this command behind the scenes for you
BeachChE
we just got our ur5 and robotiq gripper loading parts on one of our Cnc mills and it's working great but I'd like to program a few routines that require an incremental move from the robots current position. We're using the force feature to insert parts so I don't always know ahead of time exactly where the tcp is. Can anyone provide a simple example of how to move say 1" from the current position in the z with respect to a particular reference feature? I feel like this is probably obvious but I'm missing something.
