Hi pros, we recently made a quick demo to a client and thought we could share here. Basically we are using the Robotiq wrist camera to locate the corner of a frame. Then the robot modifies the robot trajectory accordingly. Note that in this demo we have two models that are fixed trajectories that we taught under the same camera locate tool. What we did is that we first taught a part that was basically a cut off corner of the frame. So the camera is afterward looking for that cut off corner on the frame. When we taught the trajectory we basically took an image of the bigger frame, programmed its trajectory under the camera locate. We then replaced the big frame by the smaller one but with the corner at the same spot in the same orientation as the bigger one and we taught its trajectory. When running the robot asks the operator for the frame model number and an if statement under the camera locate node selects the proper trajectory to perform.
Here is the video
https://youtu.be/vw9_fyOvpKM
We are kicking off demo week on DoF. Show us what you can do! What is the most challenging application you did? Show them off and help other pros who are working on similar projects.
It's time to share your knowledge and expertise! Don't forget to add videos, pictures and your robot programs.
Take a look back at some of the top demos shared on the community:
Pallet Sequence Programming by @tylermartin
https://www.youtube.com/watch?v=KUJUMcUuvX8
Coval Vacuum Generator by @Sebastien
https://www.youtube.com/watch?v=BWB7E7tr3Vk
Part Inspection Using Robotiq Products and 3D Laser Scanner from Creaform3D by @Michel_Beauchemin
https://www.youtube.com/watch?v=SUJSXvJ4vb4
Bottle Packaging with UR and Robotiq Gripper by @baghakian
https://www.youtube.com/watch?v=NxS4KFCvfU0
Wrist Camera Pick and Place With MiR100 by @Kaleb_Rodes
https://www.youtube.com/watch?v=d6cvN6TCHKM
Spiral Search Using FT300 Sensor by @Tyler_Berryman
https://www.youtube.com/watch?v=PeDMZ5XjMCo
