This program does not depend on any installation file so you can ignore this message by pressing cancel and keep your current installation file.
Each program is mandatorily tied to an installation file and it happened that when we packaged the urcap, the installation was located in the Sensor folder. However, we do not distribute installation files because it modifies the payload silently. This can be really dangerous if an operator uses the freedrive with an ill defined payload.
PierreOlivier_Proulx
Annick_Mottard
Hello, we installed an FT 300 on a UR5 and everything went smoothly until we tried to calibrate the sensor.
I have attempted to reinstall the "Robotiq_Force_Torque_Sensor-1.0.1.urcap" file with the same results.
I can not run the "calib_tool" program.
Anyone have a suggestion?
NOTE: we know the FT 300 is working because we have queried the 63350 and 63351 ports on TCP/IP (using both a Python program running on local host and a C++ program running over another machine using the static IP address we gave the UR5) and gotten good data that varies when put pressure on the payload or move the UR5 around.
