@mfadrigalan I think what you need to do is have your pallet wizard reference starting point saved in a variable and then do a pose_add to start your pallet with the offset you found out with the seek. Your new pallet would start with a pose that is your initial pose + the offset.
I would start with finding the difference in height (Z) when you find something with the seek. Use the get_actual_tcp_pose() function and do a difference between this and your reference frame to know the Z difference. You will look at the current pose digit [2] to get the Z, [0] is X and [1] is Y.
Then you could start your pallet with the new height. Use the pose_add() function, you would just add the Z from your variable to get your new pose.
hi all,
need help on programming the robot using force as seek sensor to find the top most tray and when the top most tray found it will start pelletizing from there.so i can put different number of tray everytime.
i found the program below online but i dont know how to start the pallet from there.
BeforeStart
Movej
Start
Robot Program
Wait: 0.01
MoveL
Seek_w_force
If force()<50
Stop_force_seek
return_5mm
thanks.
mart
