@Samuel_Bouchard, there are different ways to use RoboDK in force-controlled applications. The robot path can be created, simulated and programmed using RoboDK's graphical user interface. The robot program is then generated using a post processor which takes into account the robot brand the force control hardware and the force control algorithms.
This approach is brand-specific, which means that every robot must be programmed differently. Furthermore, the robot is the decision maker. Alternatively, you can use RoboDK's API to program the force control algorithms on a separate computer (we currently support Python, C# and Matlab). In this case, the PC becomes the master and the robot works as a client, executing the movements defined by the PC.
Samuel_Bouchard
Thanks for the input @Albert!
Albert
Neat video combining FT sensor, gripper and UR, programmed using RoboDK:
https://www.youtube.com/watch?v=0mYoRW0kdWY
@Albert, I'm interested to know: can you explain how your software can be used in force-controlled applications? Thanks!
