Yes, when you set up the feature check the box for using it as a variable
Awesome
Awesome
I am working on an application where we have a sensor that would detect the edge of a part. Then based on this we need to offset positions within the program. The easiest way that would come to mind would be to have the points that need to be offset referenced to a feature and we could vary that feature within the program. Is that something that is doable, varying the value of a feature as the program run?
