Hi pros,I am working on a program that requires some input from an operator on a UR5 robot. Basically in the before start part of the program I have some variable that are 'operator' variables. These have an automatic popup when I run the program. Then I am using these values, entered by the operator, to adjust some positions later on in the program. So at the end I want the operator to be able to enter the numbers but not to alter the programs. How can I do this?
If the program is in run mode, the pop-ups still occur but the operators have no access to the program. We use this in production currently.
@matthewd92 Sounds good thanks. Any easy way to have limits on the values the operator is entering? The only method that I am thinking of is having an if loop in the program that pops a message when value is outside limit and brings you back to operator variable popup.
@Sebastien that is what we do now. It would be nice if UR would add some additional functionality to this feature
@Sebastien @matthewd92 Thank you for the feedback. I agree that proposal can add value in some cases, it would only work when entering numerical values though.
Hi pros,
