Hi @Thomas
Even with the USB key, I think files within the URCaps app might be readable somehow. Perhaps a safer and robust way is to create binaries or encrypt files.
I haven't worked deeply with URScripts, but I have browsed the Robotiq 2F Gripper URCaps, and saw most of things in binary already (like Java classes or Debian executables / libraries), and others in bash scripts... you can download to check it freely here.
So the only things readable are the scripts, html and xml.
If you have important information in the scripts, you can try encryption with: http://enscryption.com/ or create a binary from the script using the open source Shell Script Compiler tool:
sudo apt-get install shcBest
PierreOlivier_Proulx
Hi everybody,
We have kind of an issue with customers asking us to lock their programs so that ther knwoledge doesn't get copied when selling an application.
Would you know how to lock an URscript or Polyscope program so that it cannot be copied by a third party ?
In that idea, we thought of the way the robotiqs tools work. Since there is the need of the USB stick to allow the robotiq product to perform, can I ask if it could be possible to work out the same solution where the program would be locked and unable to perform if the USB stick with it's key isn't found ?
I am not really sure how it performs in between what's on the key and what's protected, but would it be possible to think of a solution on the same configuration and would it protect the program knowledge of the application ?
If you have an idea, I am all ears :)
Thanks
Thomas
