Hi ! Can you provide me with the serial number of your Gripper and Controller so I can send you the proper documentation ?
Robotiq_Customer
Thank you !
Robotiq_Customer
Thank you !
Hi
I'm current doing a project involving the use of the Adaptive robot gripper 2-Finger 85 using a K3 Controller on a Robot Arm (Mitsubishi RV-2SDB) with a controller (Mitsubishi CR1DA-700) and the process will be control using a micro-controller.
Is it possible to obtain a Datasheet/User-Manual for the controller?
I also want to know if I can control the Gripper using the I/O of a Micro-controller or though USB connection?
Thank you beforehand
Best Regards
