Catherine_Bernier
I got a request from a customer about being able to measure the torque in a screwing application.
It's a good application for our FT300 since you are able to monitor and even trigger a second event once you reach the torque desired.
For a bit better resolution, we also have the FT150. Here is the spec sheet.
Note that the sensor reads the torque at a rate of 100 Hz and that the screwing tool might induce some vibrations to the sensor.
From your experience Pros, did you use our FT sensor in screwing applications?
