When we need additional IOs only, we use the WAGO units. We have also used the WAGO PLC with the additional IOs. Both are much less expensive then traditional PLC. The UR can handle around 50 additional inputs and 50 additional outputs using the WAGO units through the Modbus TCP.
Beachy
Every applications so far that we programmed did not require us to use a PLC. We had enough process power in the UR and all the IO's that we needed. I saw many post on DoF referring to PLC. What are you criteria when you decide whether or not you need a PLC. This adds cost to the projects and we simply don't want to buy it when we don't need it.
